Issue Security Level not visible on form - though helper says it is.
Brendan Andrews
A new cloud instance - I have permission to set issue security but the field doesn't appear. And when I look to add it, I'm told it's already there. This is true even once I changed back to the old view (it wasn't visible on the new on either). The field is listed in those for the screen scheme I'm using.
Brendan Andrews
The issue was that the specific security levels weren't added to any roles or groups of users.
Jira's helper said it was on the screen, though it wasn't: It doesn't check that particular permission when determining if the field is visible on the form.
5 votes
Zack Ahmed
Security Level can be viewed in the new issue view next to the Watch options.  Should see a red lock symbol.  I know!  I was expecting a field.  And don't even get me started on having an Issue Type field, gotta hover over the little icon to see those.
3 votes
Deleted user January 22, 2019
Hi @Brendan Andrews,
Make sure that set issue security is set in your permission scheme.
Here are the few resolution steps provided by Atlassian. Can you check if any of the steps may helpful for you?
https://confluence.atlassian.com/jirakb/custom-fields-or-system-fields-are-not-appearing-on-the-screen-163416168.html
Sravya
Brendan Andrews
Thanks though it turns out it wasn't associated with any of those.
Dylan H
November 4, 2019
Thanks for sharing this! Setting this on the permission scheme was what I was missing.
Jennifer Choban - HeroCoders
I'm having this problems as well. The issue security field shows on the create screen, but not on existing issues.
This what I've checked:
  • The project is associated with a security scheme
  • I have permission to set the security level
  • The Security Level is present on the screen configuration and in the field configuration scheme
  • The Security Level field is not "hidden" on the issue layout
  • The Security Level field is not in the collapsed section on the right panel
Any help greatly appreciated.
Nic Brough -Adaptavist-
October 12, 2022
Are you named in at least one of the security levels (doesn't matter how - group, role, assignee, individual, etc)?  The field won't appear if the only option available for you to set is "none" (you have to be included in a level to be able to set it)
yauhenvatsiakou January 31, 2023
Hi. I still have exactly the same problem. Checked all the items that are mentioned above. I would like to ask @Jennifer Choban  if something helped to you?
Looks like they changed user usability a little bit. I found possibility to change security level at the top (small red lock).
Like # people like this
