On this gadget, can you filter by sprint? At the moment i have an overall view of issue types within the project, but would like to see this split by sprint also?
Same applies to the pie chart - can you filter per sprint as well as per board/project?
Thanks!
HI Marie,
There are defiantly some filtering options that can be applied for sprints but I'm not entirely sure what data sets your trying to get back, can you please elaborate a bit on what your looking for?
A few things to look at are that the Issue Statistics gadget is going to be based on either a set project or a saved filter applied so adding in a filter with something like "project in (X,Y,Z) AND Sprint in openSprints()" for your saved filter would give you issues in any open sprint for the defined projects, or setting "Sprint in (a,b,c)" would give you results for those sprints in particular.
Next if you have your filters defined and are looking for the sprints the data is in and set In the value to "Sprint" in the statistic type for the gadget, it will populate the Sprints.
Let me know if either of these apply or if you're looking for something else.
earl
