Issue When Moving JIRA Issue with Sub-task: Retain Field and Mandatory Fields Prompt
Tharunkumar B
Hello JIRA Community,
I'm encountering an issue when moving an issue from one issue type to another in JIRA, specifically from "Observation" to "Defect". Initially, when I moved the issue without any sub-tasks, the transition was smooth, and I didn't face any prompts for mandatory fields or the "Retain" field values option.
However, after I created a sub-task under the issue, and then attempted to move the parent issue to the "Defect" type again, I was prompted to fill out several mandatory fields and was presented with the "Retain" field values option. This wasn't the case when there was no sub-task involved.
Can anyone explain why this happens and how I can configure my workflow or field settings to avoid these prompts when moving issues with sub-tasks? Any advice on how to streamline this process would be greatly appreciated.
Screenscheme/Field configuration same for both issuetype.but when I create a new sub-task only facing the issue.
Thanks in advance for your help!
Lisa Forstberg
August 14, 2024
Hi @Tharunkumar B ,
As you are not allowed to separate a parent and a subtask via the move, every move will automatically also move the subtasks. Perhaps you are faced with mandatory fields for the subtask when you are moving a parent/subtask.
I would check
  • the field configuration for the respective issue types in the target project that you are moving the tickets too. Any trace of these fields being required?
  • the workflows of the respective issue types in the target project - specifically look at the create issue transition for any validations
  • Are these fields present on any of the issues screens in the target project
  • Check these fields - what contexts do they have?
I think I have seen this behaviour in other environments too  but I haven't investigated it fully yet.
best of luck
Lisa
Tharunkumar B
Thanks @Lisa Forstberg
Eg:Field configuration/screen scheme same for subtask,observation,defect issuetype and also move issue within Project itself
Lisa Forstberg
August 14, 2024
Puzzeling !
If these fields are not needed in these projects at all I  would have tried to see if excluding the projects via field context would solve the popup problem during the move action.
I would also consult atlassian support to see if we can get an explanation to why these fields appear.
Best regards
Lisa
SERVER
VERSION
7.9.2
