Issue collector
Ayush Lawania
I want to add more custom fields while configuring an issue collector, the fields which I want to add are added in the create screen as well, but am not able to see those fields while configuring issue collector.
Alex Koxaras _Relational_
Hi @Ayush Lawania
If you go to your issue collector and edit it, you should be able to see all available custom fields:
Preview
Ayush Lawania
Yeah, but I am not able to see all the fields in custom section
  • Which types are these custom fields?
  • And can you confirm that on the specific field configuration are not hidden?
  • And can you confirm that they have context for the specific project?
FREE
