Issue does not exist or you do not have permission to see it
Can anyone please tell me how to get rid of this? It comes up a lot, as you're editing tickets for the most part. Our workflow, permission scheme, etc, etc is all Default. We have not made any custom flows, aside from adding a few fields.
Nic Brough -Adaptavist-
May 2, 2018
This should only appear when you reach a url you don't have permission to see, or the issue genuinely isn't there.
The only way I can think of persuading a healthy Jira to go there is to have a create process that ends up creating issues you can't see because of permissions, or a listener that picks up transition/edits and changes the security.
If you have not configured that, then I think you should go straight to support on this one, as it's a bug or fault.  Https://support.atlassian.com/contact
Thank you. Yes, we have definitely not modified those areas. And I did find that other people are seeing it as well.
Jordan Corbman
May 18, 2018
May 18, 2018
Yes, you get that message when you don't have the permissions or security level to see it.
Chad Coles May 23, 2018
We are seeing this message when adding a comment to an issue (that we are currently viewing). The comment is saved and displayed properly, even though the alert is seen. Any ideas why?
francisco.aldana@endowance.com May 23, 2018
Fyi: I was told to wait as they are working on a fix :(
Balaceanu Catalin
February 20, 2019
:D
