×Has anyone figured out how to get issue keys to export from Advanced Roadmaps in Jira Cloud? Unlike Jira, Advanced Roadmaps provides the means to export ticket hierarchies in Jira Cloud. However, When I export a plan as a CSV type, the issue key is not included in the file.
Hi @Stephanie Groot,
I did a test export and the issue key is effectively in the export. It is not where your would expect it though - I found it in column U of the exported result (so in 21st place in the file).
I hope you can find it somewhere deep into the data pile as well 😅
Hope this helps!
Wow! Thank you, truth be told, I didn't scroll that far since. I appreciate the answer :)
