My workflow consists of following statuses
Todo , In progress , In Review , Done (All statuses are allowed to transition to all statuses)
CASE 1: When i am trying to transition from Todo to In progress , in this case notification gets updated , but can't see that change.
CASE 2: When i am trying to transition from Todo to In Review , in this case notification gets updated , and change is updated too, but i can't transition further to Done or Todo
Hi @Kaushik, Vaibhav ,
welcome to the Atlassian community!
CASE 1 : what means "can't see that change?" is it reffered to status? Please, verify issue history tab to be sure that transition succesfully happened
CASE 2 : please verify that there are no condition in your transitions. If from In Review you are not able to go to Done or To DO, prabaly, there're one or more condition on the workflow.
Hope this helps,
Fabio
Thank you @Fabio Racobaldo _Herzum_ , "can't see that change" means , that when i am transitioning from todo to inprogress , in that case notification gets updated , but status does not changes. There are no condition attached to the workflow.
It's very strange! Please raise a ticket to the Atlassian support https://support.atlassian.com/contact/#/
Hello Guys,
Good day to you both, any further update on this issue, please let me know if you resolved this issue?
Raj Hiremath
