Hi all,
I have a problem with my project.
I need to create an automation that close the issue automaticly when the "Planned end date" has been passed. I give an example: "if the planned end date is 16/05/2021 6PM, the issue must closed tonight at 11.59PM."
Until now, tickets have been closed on the same day as the ticket was opened.
Can you help me?
BR,
Hi Giuseppe - so what is not working with it now?
Hi, the rule works only that the ticket closes on the day of creation and not the day set in the PLANNED END DATE field.
yes, what happens is that the ticket closes on the day of opening and not when the "Planned End Date" occurs.
Do you have any other suggestions?
Hi, the Time zone is CET.
I would like to fire the rule at 23.59 local time (not every day but on the day reported in the Customer Field Planned End Date).
BR,
I would like to set the rule that the ticket must close automatically at 11.59 pm on the day set in the custom field "Planned end time".
The set rule now closes the ticket on the same day as the ticket is created.
BR,
Hi, can you give me the correct syntax? Just to make no mistake.
BR,
