we're manually switching issue statuses,
when trying to "complete" a sprint - the prompt message says;
"the sprint contains open issues"
we didn't encounter this problem before, and we can't figure out what we did to cause this issue.
has anyone successfully dealt with this?
Hi Vital - Welcome to the Atlassian Community!
Are you sure the issue is in the last column on the board? Are there any open Sub-tasks under the issue?
nope, i've verified all possible options.
my solution has indeed solved this issue for us.
***resolved***
I've set the "APPROVED" column as the left-most column
(in project settings > columns and statuses)
Did you checked the resolution of the Issue?, try query the sprint issues and check the issue that has been open resolution.
i did,
***resolved***
Search the sprint Issues in JQL and find the Issue which is not completed.
