Issue security level schema is not working in jira
saroja muninaga August 5, 2019
I have created Issue security level schema for project . and assigned different group for each security level .
But It is not working ,any one can see the other group issues .It is highly impacting the security in project .
please assist me on this .
Alexey Matveev
August 5, 2019
Did you add the Security Level field to the create or edit field? You need to set a value to the Security Level field.
saroja muninaga August 8, 2019
Yes @Alexey Matveev  Added to edit and issue create screens .
Alexey Matveev
August 8, 2019
You should set this field to a value, if you want the issue to be secured.
