Hello all,
If you go to the Backlog there is a issue summary of not started, in progress and closed issues like shown in the screenshot (at least for me).
I find it hard to find the correct wording for this section but I have two questions:
* Is it Jira native or a installed plugin?
* Should it be clickable so we see a list of the 8 issues that are In Progress?
Cheers Alex
It is the ouf of the box feature. It is not clickable.
Hi Alexey,
thanks for the fast answer.
Do you know the name of this feature?
I also do not know what is called. This feature goes with Jira Software. It shows how many story points are in To Do, In Progress and Done.
