I have an issue to create a hierarchy level in a plan.
I followed the video: Configuring issue hierarchy above epics in Advanced Roadmaps - YouTube
But I have this issue and I am unable to create the new hierarchy level that I have configured:
Here is, below, the configuration I have done for my project. Am I missing something ? Thanks a lot for your help.
Regards
Hi @Loic Banguillot ,
welcome to the Atlassian Community!
I think the problem is that the view is not set to show issues with issue type Theme.
So, in your plan - please navigate to the Filters -> Hierarchy and check the From and To fields. You probably need to set From field to Theme.
Thanks a lot ! Its quite simple unless you don't know the trick ! :)
