Few issuetypes are missing from issue type screen scheme to the issue creation dropdown. Can someone suggest possible reason?
All new issue types created are visible in the screen scheme and not on issue create drop down.
Hi @Nikhil
Check that your required issue types are mapped in the projects Issue Type Screen mapping scheme and the Workflow Issue Type Scheme
See
https://confluence.atlassian.com/adminjiraserver/configuring-workflow-schemes-938847421.html
Tom
Hey Tom,
Yes, they are visible under issuetype screen as well as in the workflow scheme. I did attach workflows to it. However, when I create a ticket, I don't see it in the dropdown list.
It is really strange to see them missing.
Are you able to share a screenshot of the projects issue type scheme and the create issue dropdown?
Thanks @Nikhil
That's a long list :-)
Jira dropdowns limit the number of results shown. Try typing WAF into the issue type field and see if a subset is then displayed.
I did try that and that was not the case. There was a script runner infact, that was working strangely. Found fix by adding these 2 issuetypes there. Thanks for your support guys!!
Hi, I am facing similar issue. What is the solution? Which scriptrunner was causing this?
