×Hello everyone,
I'm currently facing an issue with retrieving the assignee for a Jira ticket through the Jira API URL. Despite using the API endpoint "${JIRA_URL}/rest/api/2/issue/${ticket}?fields=assignee", all I'm receiving is Null. I'm uncertain about the correct solution to resolve this.
Any insights or guidance on how to troubleshoot and fix this issue would be greatly appreciated.
Thank you in advance for your assistance!
So the NUll is coming on the assignee I am getting all the other information
Hello @DevOps iCapital
The API is working for me.
Have you tried the API without the "fields" parameter to confirm that you can retrieve all data for the issue?
Have you confirmed that the issue exists, and has an Assignee value?
For the user identity used to authorize the request, does that user have access to the project and the specific issue you are trying to retrieve?
Does the Assignee field for that specific issue actually have a person specified in it?
so the ticket has an assignee i can see the email and the person's name but assignee is blank/empty
In the results you got from extracting all the fields, can you check if there is more than one field named "assignee"?
so i run the following:
Hi @DevOps iCapital and welcome to the Community! Do you get the same result using api/3?
https://<yoursite>.atlassian.net/rest/api/3/issue/<key>?fields=assignee
