Issue with advanced automation rule
Antonio Carvetta
Morning community,
I'm trying to create a Jira automation rule to do the following.
I have two custom fields, both drop-down lists:
- Custom Field 1: Client Name(s)
- Custom Field 2: Name
I aim to automatically fill out Custom field 2 with the Custom field 1 first value.
Example:
if Custom field 1 = Jira, Confluence, Cloud, then Custom field 2 would show only Jira
I created the following JSON, but it's somehow not working.
"update": {
"Custom Field 2": [{
"set": { "value": "{{Custom field 1}}" }
Can you please help me out?
2 accepted
Evgenii
Hi, @Antonio Carvetta
Please, don't use JSON for such tasks. It can be made with standard functions of smart values.
Your customfield_2 - is standard field with "multiple select from list" type.
In Jira automation you can pull first or last value from list of values in field. Use list.first function. Here you can find examples:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-lists/
Antonio Carvetta
@Evgenii my primary issue is how/where to use the 2 custom fields
Antonio Carvetta
Or would it be something like this?
"fields": {
"Custom field 2": "{{#issue.fields.customfield_1}}{{customfield_1.first}}{{/}}"
Evgenii
@Antonio Carvetta you have to add action Edit Issue, select required field, and use there string like:
{{issue.customfield_22222.first.value}}
(change 22222 to your customfield id)
Antonio Carvetta
@Evgenii still facing issues. Let me upload an image with the automation. It may help.Screenshot 2023-07-05 at 16.53.54.png
Evgenii
Please, don't use section "Additional fields", it's made simplier. Insert my string to field upper, as shown on pic.
Antonio Carvetta
@Evgenii followed your guidance - thanks. The query runs but the field remains blank.
Evgenii
Ok, try to use {{issue.customfield_22222.first}}
Antonio Carvetta
@Evgenii still blank!
Evgenii
It's strange. What types of fields are you using? Type of field, from which you try to copy first value, and type of field, where you try to paste it?
I repeated case on my stand, everything works fine
Antonio Carvetta
Let me try to provide further details.
Both fields are 'Select List (multiple choices)
The first custom field contains 100 values, while the second one contains just 20.
I am aiming to perform the following.
If custom field 1 is filled out with 1 specific value - which I imported in custom field 2, reflect the value into the custom field 2.
If custom field 1 is filled out with 2+ values, and the first one is also present in the custom field 2 dropdown list, automatically reflect it into the custom field 2. dropdown list
Does it make sense, or do you want me to draw something up?
thanks
Bill Sheboy
July 6, 2023
Hi @Antonio Carvetta
What problem are you trying to solve by doing this?  And specifically, what is significant about the "first" value, and what does "first" mean to you?  Simply put, why do this?
Knowing these things will help the community to offer suggestions relevant to the problem you are trying to solve.
Antonio Carvetta
Hi @Bill Sheboy I explained in the above thread. Let me know if it's still unclear.
Thanks.
Bill Sheboy
July 7, 2023
You do not describe "why" (i.e., the problem you are trying to solve).  Regardless...
The suggestion already offered should work, if the different field values are aligned.  The reason is that the id values could be different with two different custom fields, and so values must be used.
Let's try this:  please write the following to the audit log immediately after the rule trigger and then post images of you updated rule showing that write and the audit log details showing the rule execution.
{{issue.your custom field name.first.value}}
If that shows nothing, it is likely you have the incorrect smart value for your field.  To find the correct smart value (or custom field id) for your field, please use this how-to article.  Essentially, you identify an example issue with your field, call the REST API with a browser, and then search for your field.
Smart values are name, spacing, and case-sensitive, so this will confirm you have the correct one.  If you do not see your field, it is likely not supported by automation rules.
https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Like Evgenii likes this
Antonio Carvetta
Thanks @Bill Sheboy and @Evgenii . Everything works as expected.
I basically wasn't aware of using the custom field key. It works now.
