Issue with automation rule not finding matching issue
Paula Manildi
We are setting up a rule when, for specific project (HD) and (via JQL) issuetype, 4 additional issues are created, copying the summary and description and linking to the original (trigger) issue. But it fails with these details:
Action details:
JQL condition
The following issues did not match the condition: HD-318 This may be due to any of the following reasons:
the issue didn't match the specified JQL (most likely)
the chosen rule actor doesn't have permissions (or issue security level permissions) to view the issue
the issue was deleted or wasn't indexed by Jira yet (in rare circumstances)
We recommend using the 'Issue fields condition' for more consistent results.
I modified the Actor from automation to an actual user and the error is still happening. What is not correct?
Brant Schroeder
@Paula Manildi
Just from what you shared it looks like the issuetype is Change and the Request Type (Customer Request Type)  is Employee onboarding.   So I believe you are correct that your JQL needs to be updated.
Paula Manildi
Hovering over the issue type only displays the issue type and then what you could do, i.e. change it. The issuetype is "Employee onboarding". jql.jpg
Brant Schroeder
Paula,
  Great, thanks for confirming.  Can you use advanced condition compare with the following and as the trigger and see if that works for you.
Paula Manildi
I have changed the rule to use Advanced compare condition and will see if it works.
Paula Manildi
I have changed to select Issue Type equals directly, which is what functioning rules use.
Still waiting for use cases to test.
Brant Schroeder
Did this fix the issue?
Like Paula Manildi likes this
Paula Manildi
Using ' select Issue Type equals ' solved the issue. Which I should have done at first, since that is what I had done in the first rule I had created.
It is a little frustrating that 3 ways are presented to do something but only one of them work!
Nikolay Petrov
We are experiencing the same issue when using the JQL. Currently, we use JQL only when we need request-channel-type as a condition or when we have OR for multiple different fields.
Is there a solution or a workaround to this problem because the automation used to work perfectly.
Best wishes,
Nikolay Petrov
Like Dana Gould likes this
Raphi Levine
I have similar issue where JQL branch automation is not finding the issue.
When I run the JQL in a filter it is returning data.  When I validate in the automation module (after adding the JQL condition, there is a validate link which shows that it found data), however when the automation runs it is not finding any data.
This does seem like a BIG Jira bug.  Any help on this?
Like # people like this
