×Hi Team,
I am running an automation script to create a default subtask for each new issue created with issue type = Story.
This I have made as a global ruleset ( enabled for 4 projects) but I get either of the below errors in 3 projects
1. The following issues did not match the condition
2. Could not find create meta data for project/typeId
Could you please help resolve the same immediately.
Hope to hear from you soon.
Deepak K P
Would you be able to add a screenshot of how the Automation is configured?
I created this in my test instance and it's working. Do you have any required fields that are not being filled out? Any validators in the sub-task workflow that would prevent this automation from working?
Hi @Deepak Parambath -- Welcome to the Atlassian Community!
Would you also please include an image of your audit log entry showing the errors? That will help the community provide ideas. Thank you.
Best regards,
