Issue with dependency injection in custom plugins in Jira 10
Ravi Saurav
August 26, 2025
Hi I am currently working on a custom plugin after upgrading from Jira 9 to Jira 10.3.2.
There are lot of changes which is exactly breaking the plugin flow.
I cannot do @ComponentImport on lots of objects(TemplateRenderer, ActiveObjects etc) from the osgi bundle into a classes such as
@Component
public class CustomPluginServlet extends HttpServlet {
@Inject
public CustomPluginServlet
(@ComponentImport UserManager userManager) {
this.userManager = ComponentAccessor.getUserManager();
or in classes such as
@Path("/samplePath")
@Component
public class CustomConfigRestResource {
private final TransactionTemplate transactionTemplate;
@Inject
public CustomConfigRestResource(@ComponentImport TransactionTemplate transactionTemplate) {
this.transactionTemplate = transactionTemplate;
Is there a way to overcome this? Secondly I have a custom class in my plugin very similar to shown below.
Named
@ExportAsService({TransactionTemplate.class})
public class MyTransactionTemplate implements TransactionTemplate {
private ActiveObjects ao;
@Inject
public MyTransactionTemplate(@ComponentImport ActiveObjects ao) {
this.ao = ao;
@Override
public <T> T execute(TransactionCallback<T> action) {
return ao.executeInTransaction(() -> {
try {
return action.doInTransaction();
} catch (Exception e) {
throw new RuntimeException(e);
How do I inject this in the class CustomPluginServlet shown above?
Tuncay Senturk _Snapbytes_
Hi @Ravi Saurav
Your REST resources can still use Spring Scanner + @ComponentImport after upgrading to Jira 10.3, but you must migrate to Jakarta packages and have Spring Scanner correctly configured. See release notes here.
- javax.servlet.* → jakarta.servlet.* (your servlet must extend jakarta.servlet.http.HttpServlet).
- javax.ws.rs.* → jakarta.ws.rs.* for REST resources.
- Build on Java 17.
Ensure you’re on Spring Scanner v2 and include the runtime so @ComponentImport/@ExportAsService generate the <component-import>/<component> entries in your plugin descriptor.
ActiveObjects & TemplateRenderer are still available as Spring services. Import and inject them only in Spring-managed classes (not raw servlets), see this page.
Your class seems fine, just ensure it’s Spring-managed and exported.
These are some clues to migrate to Jira 10.x
I hope that helps
Ravi Saurav
August 27, 2025
Hi @Tuncay Senturk _Snapbytes_ thanks for your reponse but the issue is not resolved yet.
I added jakarta dependency with provided scope because with compile scope it says its a banned dependency.
<dependency>
<groupId>jakarta.servlet</groupId>
<artifactId>jakarta.servlet-api</artifactId>
<version>5.0.0</version> <!-- Match Jira SDK / Tomcat version -->
<scope>prvided</scope>
</dependency>
Here is the stacktrace I get:
Caused by: org.osgi.framework.BundleException: Unable to resolve com.xxxx.xxx.it.applications.custom-plugin[365](R 365.0): missing requirement [com.xxxx.xxx.it.applications.custom-plugin [365](R 365.0)] osgi.wiring.package; (osgi.wiring.package=jakarta.servlet) Unresolved requirements: [[com.xxxx.xxx.it.applications.custom-plugin [365](R 365.0)] osgi.wiring.package; (osgi.wiring.package=jakarta.servlet)]
My bad, sorry!
Jira 10.x requires Java 17 but not jakarta imports (not yet for 10.3), On Platform 7, Atlassian moved many deps to Jakarta but kept javax.* package names. Switching to jakarta.* will come later on Platform 9.
So, use provided javax.servlet as the below
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>javax.servlet-api</artifactId>
<version>4.0.1</version>
<scope>provided</scope>
</dependency>
and use the import
import javax.servlet.http.HttpServlet;
for REST, I think you need to use the dependency below
<dependency>
<groupId>jakarta.ws.rs</groupId>
<artifactId>jakarta.ws.rs-api</artifactId>
<version>2.1.6</version>
</dependency>
I am not 100% sure but I'd follow these steps.
By the way, it is always better to post this sort of developing questions on Atlassian Developer Community. You'd find better/more answers there.
Ravi Saurav
August 27, 2025
Thanks @Tuncay Senturk _Snapbytes_ I will use that channel. But the @ComponentImport wouldn;t work.
