Issues and filters in Next gen project
Swati_Dubey
I cant see 'Issues & filters' in the next gen project left nav bar. Capture.PNG
elenushhh
May 8, 2019
Hello @Swati_Dubey .
Go to project settings, and there you can find the issue types, also you can add and personalize tasks by adding or removing fields.
Unfortunately there are no filters available.
Swati_Dubey
Thanks Elena. I am actually looking for 'Issues and filters' as we have in the other Jira project type. To use for creating customized reports by exporting it to excel.
Like elenushhh likes this
