This is the exception I'm getting.
Best Regards and thank you in advance,
Simdea
com.atlassian.greenhopper.manager.lexorank.LexoRankIntegrityException: Expected exactly 2 rows; the maximum marker row and the lowest ranked row for rank field[id=10005]
at com.atlassian.greenhopper.manager.lexorank.LexoRankDaoImpl.getMaximumMarkerRowAndPreviousRow(LexoRankDaoImpl.java:369) [?:?]
at com.atlassian.greenhopper.service.lexorank.LexoRankOperation.rankInitially(LexoRankOperation.java:177) [?:?]
at com.atlassian.greenhopper.service.lexorank.LexoRankOperation.execute(LexoRankOperation.java:116) [?:?]
at com.atlassian.greenhopper.manager.lexorank.LexoRankManagerImpl.performRankOperation(LexoRankManagerImpl.java:300) [?:?]
at com.atlassian.greenhopper.manager.lexorank.LexoRankManagerImpl.getRankOrRankInitially(LexoRankManagerImpl.java:86) [?:?]
at com.atlassian.greenhopper.customfield.lexorank.LexoRankCFType.getValueFromIssue(LexoRankCFType.java:121) [?:?]
at com.atlassian.greenhopper.customfield.lexorank.LexoRankCFType.getValueFromIssue(LexoRankCFType.java:29) [?:?]
at com.atlassian.jira.issue.fields.ImmutableCustomField.getValue(ImmutableCustomField.java:349) [classes/:?]
at com.atlassian.jira.issue.managers.DefaultIssueDeleteHelper$DeletedIssueEventData.collectCustomFieldValues(DefaultIssueDeleteHelper.java:288) [classes/:?]
at com.atlassian.jira.issue.managers.DefaultIssueDeleteHelper$DeletedIssueEventData.<init>(DefaultIssueDeleteHelper.java:275) [classes/:?]
at com.atlassian.jira.issue.managers.DefaultIssueDeleteHelper.deleteIssue(DefaultIssueDeleteHelper.java:120) [classes/:?]
at com.atlassian.jira.issue.managers.DefaultIssueManager.deleteIssue(DefaultIssueManager.java:719) [classes/:?]
at com.atlassian.jira.issue.managers.RequestCachingIssueManager.deleteIssue(RequestCachingIssueManager.java:232) [classes/:?]
at com.atlassian.jira.bc.issue.DefaultIssueService.delete(DefaultIssueService.java:402) [classes/:?]
at com.atlassian.jira.bc.issue.DefaultIssueService.delete(DefaultIssueService.java:378) [classes/:?]
at com.atlassian.jira.web.action.issue.DeleteIssue.doExecute(DeleteIssue.java:23)
Hi Simdea,
The lines to focus on currently are the following:
Take a look at Several actions such as issue ranking, move, export are failing:
Run the following Query in the DB:
SELECT "FIELD_ID", "ID", "ISSUE_ID", "LOCK_HASH", "LOCK_TIME", "RANK",
"TYPE"
FROM "AO_60DB71_LEXORANK"
WHERE "FIELD_ID" = 10005 AND "TYPE" IN (0, 2);
With the above Query you should see Exactly 2 rows as displayed here:
FIELD_ID | ID | ISSUE_ID | LOCK_HASH | LOCK_TIME | RANK | TYPE
10005 | 7 | -9223372036854775808 | | | 0|000000: | 0
10005 | 8 | 9223372036854775807 | | | 0|zzzzzz: | 2
(2 rows)
If the above does hold true in your instance do the following:
Run the following statements in the database:
insert into AO_60DB71_LEXORANK values
(DEFAULT,10005,7,-9223372036854775808,NULL,NULL,'0|000000:',0);
(DEFAULT,10005,1,9223372036854775807,NULL,NULL,'0|zzzzzz:',2);
Start JIRA
Re-index JIRA
If that does not work let us know and we'll go from there.
Branden
Hello Branden and thanks for your fast response. Unfortunately, the query returned no results. Any more ideas, I just tried to clone an issue and also did not had any luck.
Best Regards and thank you in advance again,
Simdea
I actually had the same issue as Simdea. So as Branden suggested I :
1) Stopped Jira service
2) Ran the below statements in the database
insert into AO_60DB71_LEXORANK values(DEFAULT,10005,7,-9223372036854775808,NULL,NULL,'0|000000:',0);
insert into AO_60DB71_LEXORANK values(DEFAULT,10005,1,9223372036854775807,NULL,NULL,'0|zzzzzz:',2);
3) Ran the below statement to validate that the table now had the 2 rows:
select * from AO_60DB71_LEXORANK;
4) Started Jira service
5) Ran an integrity check
6) Re-indexed the database
And the issue was solved. Thank you Branden.
Works well, thanks.
However, if you experience the issue, make sure that you use correct FIELD_ID value which is id of the Rank field. For example on my instance Rank had the id 25700, not 10005.
