"customfield_11361": [ { "self": <API_URL>, "id": "104743", "description": "", "name": "ABC 1.0", "archived": false, "released": false, "releaseDate": "2022-07-31" } ]
"customfield_11361": [ ]
>>> from jira import JIRA >>> headers = {} >>> headers["Authorization"] = "Bearer <Token_key>" >>> jira_obj = JIRA(server=<JIRA_Server_URL>, options={"headers":headers}) >>> jira_obj.issue(<JIRA_Ticket>) <JIRA Issue: key=u'<JIRA_Ticket>', id=u'1247768'> >>> jira_obj.issue(<JIRA_Ticket>).fields.customfield_11361 [<JIRA Version: name=u'ABC 1.0', id=u'104743'>] >>> jira_obj.issue(<JIRA_Ticket>).fields.customfield_11361[0] <JIRA Version: name=u'ABC 1.0', id=u'104743'> ... Cleared the verified version manually in the JIRA Ticket directly. ... >>> jira_obj.issue(<JIRA_Ticket>).fields.customfield_11361 [] >>> jira_obj.issue(<JIRA_Ticket>).update({'customfield_11361': [{'name': 'ABC 1.0'}]}) Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/home/naveen.shankar/auto_validator/my_nutest_virtual_env/lib/python2.7/site-packages/jira/resources.py", line 412, in update super(Issue, self).update(async=async, jira=jira, fields=data) File "/home/naveen.shankar/auto_validator/my_nutest_virtual_env/lib/python2.7/site-packages/jira/resources.py", line 178, in update self.self, data=data) File "/home/naveen.shankar/auto_validator/my_nutest_virtual_env/lib/python2.7/site-packages/jira/resilientsession.py", line 136, in put return self.__verb('PUT', url, **kwargs) File "/home/naveen.shankar/auto_validator/my_nutest_virtual_env/lib/python2.7/site-packages/jira/resilientsession.py", line 126, in __verb raise_on_error(response, verb=verb, **kwargs) File "/home/naveen.shankar/auto_validator/my_nutest_virtual_env/lib/python2.7/site-packages/jira/resilientsession.py", line 45, in raise_on_error r.status_code, error, r.url, request=request, response=r, **kwargs) jira.exceptions.JIRAError: JiraError HTTP 415 url: <API_URL> response headers = {'X-ANODEID': 'JiraProd_i-0ff79dea69bc39a25_10.150.20.84', 'X-AUSERNAME': 'svc.eng.jirautotriag', 'Content-Length': '0', 'X-XSS-Protection': '1; mode=block', 'X-Content-Type-Options': 'nosniff', 'Set-Cookie': 'AWSALBTG=30RQv3GKZcjCtYxL2RGbsbH8yLx1ey8ma64o2iaAZUA/7Nm/r5cAGQ0FmfvnzKLZt8SMshr7J6+dF6pRrFR2p608sS2pmYoHoevjiesIvqEi5AY0Xnvxe93mePiHpM6nN55WMTqV9CkTC0opuuQVnp+c/UZ2ZYnyONCEiuiFOQ7grK1nmn8=; Expires=Sun, 25 Sep 2022 06:28:00 GMT; Path=/, AWSALBTGCORS=30RQv3GKZcjCtYxL2RGbsbH8yLx1ey8ma64o2iaAZUA/7Nm/r5cAGQ0FmfvnzKLZt8SMshr7J6+dF6pRrFR2p608sS2pmYoHoevjiesIvqEi5AY0Xnvxe93mePiHpM6nN55WMTqV9CkTC0opuuQVnp+c/UZ2ZYnyONCEiuiFOQ7grK1nmn8=; Expires=Sun, 25 Sep 2022 06:28:00 GMT; Path=/; SameSite=None; Secure, JSESSIONID=93EB48BE1E6601CA9D0F5F1B2065C062; Path=/; Secure; HttpOnly, atlassian.xsrf.token=B14E-GL73-6FKZ-OP3B_a78d88ea0c35e582f026ada3d9f98b6ece47285f_lin; Path=/; Secure, AWSALBAPP-0=AAAAAAAAAAA3k++saeQ+htH2m7IzGNyst8sx9HUMRQ3aJCFVRuxgIlV4QIoLMgM32mgmZI+o0hsK93RUPAeVl2tzJpmfjup20SVnealEWGbmqDdtpdatO6rxxsLx+H1qYI19avkc0Xbxkss=; Expires=Sun, 25 Sep 2022 06:28:00 GMT; Path=/, AWSALBAPP-1=_remove_; Expires=Sun, 25 Sep 2022 06:28:00 GMT; Path=/, AWSALBAPP-2=_remove_; Expires=Sun, 25 Sep 2022 06:28:00 GMT; Path=/, AWSALBAPP-3=_remove_; Expires=Sun, 25 Sep 2022 06:28:00 GMT; Path=/', 'X-Seraph-LoginReason': 'OK', 'Strict-Transport-Security': 'max-age=31536000', 'X-AREQUESTID': '388x3995248x3', 'X-ASESSIONID': '1nq6mq5', 'Connection': 'keep-alive', 'Cache-Control': 'no-cache, no-store, no-transform', 'Date': 'Sun, 18 Sep 2022 06:28:00 GMT', 'Referrer-Policy': 'strict-origin-when-cross-origin', 'Content-Type': 'text/html;charset=UTF-8'} response text =
Can you try this:
issue.update(fields={'customfield_11361': [{'name': 'ABC 1.0'}]})
I had tried this as well but yields with the same results unfortunately
>>> jira_obj.issue("ENG-488911").update(fields={'customfield_11361': [{'name': 'ABC 1.0'}]})
url: https://jira.nutanix.com/rest/api/2/issue/1247768
response headers = {'X-ANODEID': 'JiraProd_i-0079ce0126cf8d38c_10.150.20.8', 'X-AUSERNAME': 'svc.eng.jirautotriag', 'Content-Length': '0', 'X-XSS-Protection': '1; mode=block', 'X-Content-Type-Options': 'nosniff', 'Set-Cookie': 'AWSALBTG=Uxxfmb3lHmPRejNHUeYUtIfkutmXbuHD1zPr3INRbtvIWb1AeCFo+qhb9Jly4o8l+EYfbbJX3v6gvWnpMIoMD4ps5sZAgadCFzxnDtW/9EO3UqfaJoSZnm+PmG5rdRtz8OwriUoFYF39VFYn/vEsdBdOlv1jeaWMg3EkhupSfb9ff/a2PHw=; Expires=Mon, 26 Sep 2022 13:54:33 GMT; Path=/, AWSALBTGCORS=Uxxfmb3lHmPRejNHUeYUtIfkutmXbuHD1zPr3INRbtvIWb1AeCFo+qhb9Jly4o8l+EYfbbJX3v6gvWnpMIoMD4ps5sZAgadCFzxnDtW/9EO3UqfaJoSZnm+PmG5rdRtz8OwriUoFYF39VFYn/vEsdBdOlv1jeaWMg3EkhupSfb9ff/a2PHw=; Expires=Mon, 26 Sep 2022 13:54:33 GMT; Path=/; SameSite=None; Secure, JSESSIONID=C5C5C4C1C59C4F041524E326C118C4A6; Path=/; Secure; HttpOnly, atlassian.xsrf.token=B14E-GL73-6FKZ-OP3B_3a607d688950fa39757b93fa02be73cf9ca49885_lin; Path=/; Secure, AWSALBAPP-0=AAAAAAAAAAB+eM7eDBFf84O+IW5PVHugNl4hllLR4LLaJPNw1uj5j1UjdRUsbQNcWnSREYnVmyTD0fzgCAdP8r5v6EiaOMm2xju1X6jBEKaSz8BZoBx/U6McarbK9QDj+PMpFXO+ib7gbZ0=; Expires=Mon, 26 Sep 2022 13:54:33 GMT; Path=/, AWSALBAPP-1=_remove_; Expires=Mon, 26 Sep 2022 13:54:33 GMT; Path=/, AWSALBAPP-2=_remove_; Expires=Mon, 26 Sep 2022 13:54:33 GMT; Path=/, AWSALBAPP-3=_remove_; Expires=Mon, 26 Sep 2022 13:54:33 GMT; Path=/', 'X-Seraph-LoginReason': 'OK', 'Strict-Transport-Security': 'max-age=31536000', 'X-AREQUESTID': '834x4614667x2', 'X-ASESSIONID': '5t1ttq', 'Connection': 'keep-alive', 'Cache-Control': 'no-cache, no-store, no-transform', 'Date': 'Mon, 19 Sep 2022 13:54:33 GMT', 'Referrer-Policy': 'strict-origin-when-cross-origin', 'Content-Type': 'text/html;charset=UTF-8'}
response text =
