JIRA Automation | Cron syntax
Jim Kinter February 12, 2021
Really getting into the JIRA automation, and have a question regarding the cron syntax for scheduled tasks.
I know how to do 9am on 2nd tuesday of each month, with the 3#2, but was curious if there is a way to do  2nd tuesday + 3 days (3 days after the 2nd tuesday)?
Would 3#2+3 work? Havent tried it, guessing that syntax actually wouldnt, but wondering if there is some syntax that would/known? I know its a stretch...
Paloma Fondon Araujo
February 12, 2021
Hi @Jim Kinter
You can try the cronmaker application to introduce the values and translate them into cron expression you are looking for
I hope it helps you
Greetings
Yeah, I tried 0 0 9 ? 1/1 3#2+3 * and it blew an error (like I expected).
Ill see how I can get creative starting with 0 0 9 ? 1/1 3#2 * and then maybe set the due date +3 or something.
Thanks for trying (and showing me that link (I usually use crontab.guru)
Like Paloma Fondon Araujo likes this
Darryl Lee
Wouldn't 3 days after the second Tuesday always be the second Friday?
0 0 9 ? * 5#2
Jim Kinter January 12, 2022
while 6#2 would be the 2nd friday, it would not be the friday after the 2nd tuesday (3#2+3) if the 1st of the month fell on Wed/Thu/Fri .
