JIRA Automation Rule
Amit Bisht
I have created this automation rule, when I create an epic Story, Enahncement and QA Tasks are automatically added and I have addedd issue context field "Developer".
The screenshot I have attached, when I change the Developer of Story the Developer is geeting changed same I need for Enahanement, saying that when I chage the Developer of Enhancement the same should be changed. But right now it not happening
Thomas Gallagher
Hi Amit,
Could you please also include a screenshot of the "Then: Edit issue fields" component as well?
Thomas, ServiceRocket
Amit Bisht
@Thomas Gallagher Here it is: Screenshot 2024-09-03 at 2.36.50 PM.png
Thomas Gallagher
Thanks @Amit Bisht
It looks like in the "If: Issue matches JQL" component you are filtering for issues that include the word "Development" somewhere in the Summary. Does changing the "If: Issue matches JQL" component from summary ~ "\"%Development%\"" to the alternatives below produce the desired result? Please let me know once you've tested, thanks!
summary ~ "\"Development\""
summary ~ "*Development*"
summary ~ "\"*Development*\""
