JIRA Automation - Send email when issue is blocked with duration in Blocked Status
Devender Singh June 1, 2023
Hi All,
I am trying to create a JIRA Automation that will send email when an issue is Blocked with time in Blocked Status. I am able to send emails, however unable to find a way to calculate the time it was in Blocked status.
Mark Segall
Hi @Devender Singh - Unfortunately, you cannot natively track time in status with automation via a smart value.  You could do this instead:
  1. Create a custom date field to track time in status
  2. Use automation to populate this field when the issue transitions to a new status
Automation would look something like this (I'm using a fictitious field called Transition Date in my example):
  • TRIGGER: Issue Transitioned
  • ACTION: Edit Issue (Transition Date)
    • {{now}}
For your email rule, it would look something like this:
  • TRIGGER: Scheduled
    • status = Blocked
  • ACTION: Send Email
    • {{issue.key}} - {{issue.summary}} has been BLOCKED for {{issue.Transition Date.diff(now).businessDays}} business days.
Note - This is calculating business days, but you could substitute with any of the options described in this documentation:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/
Devender Singh October 11, 2023
Thank you Mark.. Appreciate you help.
Like Mark Segall likes this
Emre Toptancı [OBSS]
Hello @Devender Singh ,
You can do this by simple filter subscriptions.
Go to Jira's issue search screen. Search with a JQL query like below:
project = ABC and status = Blocked and not status changed FROM Blocked AFTER -3d and assignee = currentUser()
The query is pretty self-explanatory. This will filter the issues "in the ABC project" that are "currently in Blocked status", "was not moved away from Blocked status in the last 3 days" (because an issue might be unblocked and blocked again), and "is assigned to the current user". (You can modify the query according to your specific needs)
Save this as a "JQL Filter". Then go to the "Details" menu of the filter. There, you can create a subscription for yourself or (if you have the necessary Jira permissions) a subscription for others.
A subscription will send the issues that match the JQL as an e-mail with predefined intervals.
(If you create a subscription for a group of users, please note that this query will run for all those users for each cycle. This might cause a significant load on your server if you have thousands of users. So use this with caution.)
EmreT
