JIRA Behaviour script throws error for fields in non mapped projects create screen
Krishnakumar Parameswaran June 5, 2019
I've a Behaviour script in initiator for create screen only for project x and its IssueTypes.
Now i'm getting the below error in another projects create screen which is having separate workflow and create screen.
Can anyone help me on this ?
Antoine Berry
If you are positive your behaviour does not apply to this project, you should check its field configuration, as well as the create transition validators.
Yes, I've checked field configurations for the second project. It seems to be fine and regarding the transition validates will be trigger once the form is submitted , in my case i'm not able to create issue.
Antoine Berry
You will not be able to create the issue if you have a validator that specify that the Component field is required in the create transition, so make sure this is not the case.
Antoine Berry
And what I meant by checking the field configuration is checking that the component field is optional like on this screenshot (sorry if you knew that already) :
@Antoine Berry we are not using the system component field. we have a custom field for components which is currently optional.
Antoine Berry
Have you checked the create transition validators of the workflow used by this issue type/project ?
i checked the infected projects workflow. There is no workflow condition for this Issue Type / field
Antoine Berry
Not sure if this what you mean, but I am talking about the create transition validators :
image.pngOtherwise, I would check if there is a specific context for this custom field, and lastly check the behaviours again, or any other app that could have this functionnality.
Yes , i checked the same only
Antoine Berry
Well if you have this issue since you added the behaviour it probably comes from here... could you provide a screenshoot of your behaviours configuration?
