JIRA-Bootstrap FATAL JIRA will be locked
Sairaj Naidu June 2, 2019
While starting the Jira software instance we are getting below error in /opt/atlassian/jira/logs/catalina.out
JIRA-Bootstrap FATAL      [c.a.jira.startup.JiraStartupLogger] Startup check failed. JIRA will be locked
we deleted the .lock file in JIRA_HOME and still the same issue and we verified in /var/atlassian/application-data/jira/log as well but it is empty.
Can you please help us on high priority ?
Thank you,
Sairaj
Andrea Maria Loi March 27, 2024
In Jira 7.1.6 it occurred to me due to a new SQL Server driver.
I just had to open config.bat, check DB configuration and save.: the driver has been updated and the problem was resolved
etienne
June 17, 2022
Got the same issue. My JIRA_HOME variable was not set correctly. Setting it up in the setenv.sh resolved my issue
Michael Thompson
June 3, 2019
You should delete the file $JIRA_HOME/.jira-home.lock and the directory $JIRA_HOME/plugins/.osgi-plugins/felix, then start as the Jira user.
William_Orantes
June 22, 2020
I have the same problem, my version of jira server is 5.3 and today the server reached 99% consumption due to tomcat, I restarted the installation and when I wanted to start it again it did not work, and it threw me that error. Delete the log as you and the Felix directory say and I did not get any results
