JIRA Dashboard with latest comments on top
Sarah
I need a possibility to show all latest comments for a certain filter. I though about a Dashboard showing this... is this possible?
E.g.
ID #1234 21.10.19: Comment: please send to customer
ID #998: 20.10.19: Comment need more information of the test case ...
Thanks.
Jack Brickey
the comment field isn't available for display in the filter results. Please reference (vote/watch) this issue - JRACLOUD-2734
However, consider the following solution. If you do not already have it, add Automation for Jira addon app. and use the comment trigger to copy the comment into a custom text field (e.g. "latest comment"). There is a free version (Lite) that will also work but given you are going to be working off comments then you likely will blow past the monthly allotment of 300 automations.
Sarah
Thank you : )
Aron Gombas _Midori_
There are multiple Jira apps that will display the last comment as a custom field.
You can then include the custom field's column in Issue Navigator and your use case is solved!
Andrew Laden
October 21, 2019
You can also do with with a SIL scripted custom field. Using the "power custom fields" addon.
string[] lastCommentDetails = getLastComment(key);
if(!isNull(lastCommentDetails)){
    return lastCommentDetails["text"];
return "";
https://marketplace.atlassian.com/apps/1210749/power-custom-fields-for-jira?hosting=server&tab=overview
