JIRA.Forms.createCreateIssueForm is not showing combo box for sprint
Subhajit Bhuiya September 25, 2018
We are using following code to bring Jira's creation dialog. All the fields are working fine except "Sprint " field. It supposed to show a combo to choose but it is not showing anything to choose.
var issueForm = JIRA.Forms.createCreateIssueForm({pid:${projectId}});
var dialog = issueForm.asDialog({windowTitle: 'Create Issue'});
dialog.show();
Daniel Eads
September 27, 2018
Hi Subhajit,
I'm not sure of your use-case but you should consider using an Issue Collector instead of manually trying to trigger the creation screen. Jira generates the code necessary for a Collector to work properly and lets you embed the collector in other systems besides Jira.
Daniel
Subhajit Bhuiya October 1, 2018
This does not fit into our use case. The scenario is to show issue creation dialog from a separate application. Jira does support JIRA.Forms.createCreateIssueForm. See the below community post.
https://community.developer.atlassian.com/t/how-to-open-create-issue-dialog-with-callback-after-issues-have-been-created/3083
This is a defect with Jira. Can you please tell me how to open a defect gainst Jira development team - Any specific url for that?
Subhajit Bhuiya October 11, 2018
@Daniel Eads this is what I got
It is a select field instead of input field and also it is hidden. I have only imported this in my code
$webResourceManager.requireResource("com.atlassian.jira.jira-quick-edit-plugin:quick-form")
Am I missing anything?
Daniel Eads
October 12, 2018
Can you clarify where you're trying to bring up this screen? The developer post you linked to is about triggering the Create screen in Jira itself. You mention "The scenario is to show issue creation dialog from a separate application". Is the "separate application" a plugin in Jira, or is it an entirely different application?
Subhajit Bhuiya October 12, 2018
@Daniel Eads Its very simple. We have written a GET API which any application can call and we send back the creation dialog as
issueForm.bind('sessionComplete', function(evt,issues) {
## process issues
dialog.show();
