JIRA Issue Age scripted field
Ash
May 23, 2017
We are usingbelow code to get Issue agein JIRA 7.3.6
import com.atlassian.core.util.DateUtils
DateUtils.getDurationString(((new Date().getTime() - issue.getCreated().time) / 1000) as Long)
output looks like 20w 3h 23m
is there anyway we can get only days.
Ashish.
Chander Inguva
May 23, 2017
Hey Ashish,
Try this
def issue = ComponentAccessor.getIssueManager().getIssueObject('CIT-8991')
def x = Math.ceil(new Double((((new Date().getTime() - issue.getCreated().getTime())/(1000*24*3600)))))
Hope this helps
Regards
Chander
Ash
May 24, 2017
Thank you Chander it worked.
Marc Jason Mutuc
June 6, 2017
Is it possible to exclude the weekends?
Ash
June 7, 2017
No, please do let us know if u figured it out
Like # people like this
NareshBusireddy January 30, 2018
Hi Chander,
I've tried your answer in JIRA 6.3.6. Encountered an error as "Cannot invoke method getCreated() on null object" Can you please suggest how to get rid off this one. I'm using the same script that you've given above. Let me know if something need to get modify in the script.
Naresh
Nic Brough -Adaptavist-
January 31, 2018
Your code is not getting an issue.  You will need to fix that.
NareshBusireddy January 31, 2018
This issue is fixed now.
