JIRA.Issue.getIssueId() doesn't work for Next-Gen based projects
Nikita_Ishkov August 27, 2019
Unfortunately API doesn't work
JIRA.Issue.getIssueId() - returns null (for issue page view/ quick issue view modal)
JIRA.Issue.getIssueKey() - returns null (for issue page view/ quick issue view modal)
张驰 August 30, 2019
I have the same problem.
I found that when page has loaded, print "JIRA.Issue.getIssueKey()" in console and then i can return the correct issueKey.
Maybe the timing are different between issue page and next-gen page.
Nikita_Ishkov August 30, 2019
it's always null for me, not depends that page loaded or loading
not depends on page opened directly by link or through navigation
张驰 October 28, 2019
Now  I found  JIRA.Issue.getIssueKey() is not work in some page, so I use Meta.get("issue-key") instead.
