I'm trying to check if the assignee of a ticket hasn't changed for a specific amount of time (e.g. 3 days). As an alternative I could search for comments not being updated (which might be the better way).
As our sprints are a week long I can't go with "updated" it seems, as a ticket is updated when I finish last weeks sprint and start the new one.
This is my idea (which didn't work):
project = RS AND status in ("Warte auf Umsetzung", "In Arbeit", "Überarbeitung erforderlich", "Wieder geöffnet") AND updated <= -1d AND assignee in (EMPTY) AND Sprint in (futureSprints(), openSprints())
Best regards,
Andrés
project = RS AND assignee in (Reuter) AND assignee changed to (Reuter) before -2d AND Sprint in (futureSprints(), openSprints()) AND NOT status = Geschlossen
You can right a JQL query like this to check if the assignee was not changed for 3 days:
not assignee changed after 3d
But you can not do the same for the comment field out of the box.
it works better now, but still I don't see all tickets that have had their assignee changed (to empty).
I'm guessing that the problem comes from the fact that I am not assigning a specific user, but setting it to 'empty'.
When checking all activities I actually don't see the assignee being change to empty either.
Query looks like this now: "project = RS AND status in ("Warte auf Umsetzung", "In Arbeit", "Überarbeitung erforderlich", "Wieder geöffnet") AND assignee in (EMPTY) AND NOT assignee changed after 1d AND Sprint in (futureSprints(), openSprints())"
Try like this:
not assignee changed after -3d
It's still not working. The query also shows me tickets that have been changed and hour ago. :(
I again changed the query a bit to make sure that tickets, that have been assigned to "Reuter" for at least a day (at least that was my intention):
project = RS AND assignee in (Reuter) AND assignee changed to (Reuter) after -3d AND assignee changed to (Reuter) before 1d AND Sprint in (futureSprints(), openSprints()) AND NOT status = Geschlossen
But that doesn't works either. Not sure what I'm still making wrong.
I would have thought that this was a more common query to check wether a ticket is in someones possesion for longer than a specific amount of time.
I did not notice the NOT keyword before the assignee field in your query. That is why you get these results
There isn't a NOT keyword in my latest iteration, but you have me thinking there tbh.
The goal is to identify all tickets that have been assigned to Reuter for more than 2 days, but I can't figure out how the JQL should look like.
This seems to do the trick:
It is good, if it works for you!
