JIRA Lock on Server
jira practice2021
March 10, 2021
My JIRA is locked. How to unclock my JIRA and run the application.
Milan Chheda [INFOSYSTA]
March 10, 2021
Hello @jira practice2021 ,
Can you please update the question correctly with JIRA server and remove cloud label from it?
It seems, there is a problem with plugin cache somewhere and the best solution for this would be to delete plugins cache and restart JIRA service. In case, it doesn't work, please share error from the atlassian-jira.log file.
~ Milan
Fabio Racobaldo _Catworkx_
Hi @jira practice2021 ,
I agree with @Pavel Junek , it seems a server instance. Try to stop JIRA and remove cache related to plugin (https://codedoers.atlassian.net/wiki/spaces/SUPPORT/pages/1165361153/How+to+delete+clear+plugins+cache+in+Jira) and then try to restart.
Fabio
please raise a ticket to Atlassian Support https://support.atlassian.com/contact
Fabio
Nic Brough -Adaptavist-
March 13, 2021
Your Jira Server is not "locked", it is struggling to start all its components.
Have a look at https://confluence.atlassian.com/jirakb/jira-startup-fails-with-message-that-required-plugins-are-not-started-254738702.html
Pavel Junek
Hi @jira practice2021,
Welcome to Atlassian community!
Did you enter your Cloud URL correctly? It's xxxyyyy.atlassian.net
What screen do you see? This one?
Pavel
jira practice2021
March 10, 2021
yes I entered my URL Correctly, but it is not opening. Following is my screen apperance.
Pavel Junek
Thank you for your reply. But according to the Screenshot, it looks like it's not a Jira Cloud - aren't you using the Jira Server version?
