JIRA OnDemand, "project already exists"
Philip Ip
August 26, 2014
Hi, i tried to create a project called "QA Team", with key QAT, it said "error, please check with JIRA admin" I am the jira administrator.
when i tried to create the project again, it said "project name already exists", but i don't see it in the list of projects.
Is it possible to reset the name and key so that i may be able to use it?
Thank you
-Philip
Chag
August 26, 2014
the project does not show up at all? check under project list or go to jira admin > projects and see if it shows there and edit the project. In there you can change the key.
Michael Ramos de Almeida
August 15, 2018
Thank you for your answer, it has helped me a lot!
Philip Ip
August 26, 2014
it doesn't show up under Projects -> View All Projects
but it does show up under JIRA ADMIN -> Projects
how do i get it to show up under projects -> View all Projects
Mina Gray
October 1, 2020
In my 4-5 years of working with JIRA, I never knew this. Wow. Thanks for this tip, it solved my problem!
Chag
August 26, 2014
under jira admin > project slect the project you want and click administration. Go under permissions and and check the permissions for "brose projects" you can change to or add jira-users
Nic Brough -Adaptavist-
August 26, 2014
Yup, sounds like you don't have access to the projects.
Remember Admin rights give you access to admin functions, not everything automatically (because that's a terrible access model), so if you want to see a project as a user, you need to make sure you give yourself permissions
