I have created jira plan for the team with some custom fields. However when I share the plan on confluence (copy pasting the share link on confluence), the displayed jira plan does not have the custom fields in them. How do I ensure the custom fields are visible on confluence page ?
Welcome to the community,In confluence you can find Jira issues in "+" i have attached the image below for your reference once search for Jira issues there you can find the JQL or project then it will show all issues there you can find the fields whatever fields required you can select that fields
Hope this helps
The issues are already shown in jira plan. My issue is that the custom fields that I can see in the jira plans page is not the same in confluence when I add embedded link. Basically the custom fields I have used in the jira plans vanish in confluence.
@Preetham Bhat i have tried in my confluence embedded jira issue it is showing all the fields,images shows below for reference
