JIRA Query Help
reddymanuja February 18, 2020
I am trying find what's the way to know if each of my tasks have components or not instead of going to every work item. Is there a query to run to do this? Please advise.
thanks,
Manuja
Dorota Gut-Knapik
Hi @reddymanuja,
You have two options (let's say you have project key TEST):
  1. Write a query that shows you all items without components and save is as a filter:
    1. project = TEST AND component is EMPTY
    2. You can subscribe this filter so it will send you an email notification with items listed.
  2. Write a query that shows you all items in the project:
    1. project = TEST
    2. Add it to Two Dimensional Filter on the dashboard, where Y axis is components and X axis, e.g. an issuetype:
reddymanuja February 19, 2020
can you come online to help?
Mikael Sandberg
Hi @reddymanuja,
Welcome to Atlassian Community.
This JQL should get you all issues that do not have a component: component is EMPTY
how or where do we run this? please advise.
Mikael Sandberg
Go to Issues > Search for issues. If you have not used the advance search before it is set to basic, just click advanced and enter the JQL.
Thank you! I see it now.
