JIRA: Single Level Group By Report - Custom Field not available to select as statistic Type
George Kouris
February 3, 2017
I created a custom field called Severity
I then went to do some reporting - wanted to show all defects and group by severity
The custom field - "Severity" isn't even available in the Statistic Type drop down for me to select
Seriously?
Nic Brough -Adaptavist-
February 3, 2017
What type of field is it, and does it have a searcher?
George Kouris
February 3, 2017
Select List (single choice) Custom Field
What is a searcher?
 I simply  tried to perform a simple filter on this new custom field of severity within my Project....whats crazy is that I see Severity as a column
February 4, 2017
A searcher is a block of code that tells JIRA how to index and search for data in the field.
A single-select will default to having a select-list searcher, and it is very unusual for an admin to ever remove a searcher, but you should check.  Go to admin -> custom fields -> your field -> edit - the searcher selected should appear under the name of the field.
If there is no searcher, this behaviour would make sense - it can't report on fields there is no reporting data for.  But if there is a searher, it becomes a bit more complex.
MilanCiti January 5, 2019
Hello Nic,
I have similar case, one of our custom field has searcher template : Free Text Searcher and it doesn't not appear in drop down list Statistics Type. We have JIRA tickets that have custom field populated and JIRA had been re-index. Is there any suggestion, what to do?
Thank you.
Milan
January 6, 2019
It won't appear for the group by report because it's nonsense for a free text field.  Each value in a free text field is expected to be different, so all you would get is a group with 1 line for every issue.
If your information is logically group-able, then you've used the wrong type of field to capture it.
MilanCiti January 8, 2019
Hi Nic,
It make sense, thank you for your confirmation.
Milan
