Is there any way we can export and import JIRA watchers list using CSV or any other format?
For just one issue or one project or multiple issues across projects?
I think the only way may be directly working with the database.
Thanks for your reply, complete project. when we export data into excel it just shows numbers in watchers data.
I would use the CSV Importer to add the watchers
https://confluence.atlassian.com/adminjiraserver071/importing-data-from-csv-802592885.html
or the JIRA REST API
https://docs.atlassian.com/jira/REST/server/#api/2/issue-addWatcher
Thanks Matt, We are also looking for CSV import, but how can we export watchers list to CSV.
