×Hi Jira Community,
We would like to update the statut of an issue with gitlab.
i.e. : with we merge a branch into develop, the statut of the issue goes from "code review" to "PO validation".
Thk
Hello @Antoine NICOLLE ,
If I understand correctly, you are searching for a way to integrate Jira with Gitlab and transition a Jira issue on a commit or on a merge request.
If that's the case, then please follow the steps in the below documentation page from Gitlab:
If that's not the case, or if you are already following the steps in the above page but you are having issues, please provide more details.
Dario
Hello Dario,
Bonne année 2019 :)
I finally find the article speaking about setting trigger in the workflow : https://confluence.atlassian.com/adminjiracloud/configuring-workflow-triggers-776636696.html
Antoine.
Happy new year to you @Antoine NICOLLE ! :)
Just to clarify, is this the article that you are following and is giving you problems or by following the article you were able to make this work?
Dario
Thanks for letting us know and for sharing the solution @Antoine NICOLLE !
It would be nice if you copy-paste the article into a new reply and accept the answer, so that this thread will be marked as solved (otherwise you can accept my answer but that's not fair since I didn't do much here ;) )
Dario
Hi all,
Just wanted to update this thread to let you know there is now a native automation trigger for GitLab with Jira Cloud. We are running a webinar soon to walk through how it works and show some use cases in how to automate from Gitlab to Jira. Feel free to register here: https://www.atlassian.com/webinars/software/automate-across-gitlab-and-jira
Cheers!
