×The JIRA activity stream is not showing thumbnails from Confluence, see attached screenshot.
I examined the URL of the links, and it appears JIRA/Confluence has added an additional / to the link, i.e. instead of https://confluence.mycompany.com/ we have https://confluence.mycompany.com// - notice // (added bold for emphasis):
https://confluence.mycompany.com//download/attachments/2359301/Mia-persona?version=1&modificationDate=1505378799593&api=v2
When I remove the additional /, Confluence shows the thumbnail, if I access the URL with "//" I get a java.lang.NullPointerException error
Hi Shubash,
It looks like you're going to need to modify a proxy setting such as proxy_pass, ProxyPassReverse or mod_proxy to resolve this.
Take a look at the following resources for additional guidance:
Solved: After setting up Nginx to proxy to JIRA, none of my assets (CSS, JS or images) load
404 page as a result of double-encoded slashes in the URL when using Apache
Take a look at the resources I provided and that should provide some good clues as to where to go to fix this.
Branden
Thank you for your response. I have begun investigating but my configs looks correct. There are no trailing slashes.
Furthermore, everything else appears to be working correctly.
For reference, I'm using Nginx reverse proxy.
