Team
I have below requirements, pls advise thanks
If in ticket, region mentioned as APJ then it remind to IT agent send mail xxxx 6 am to 2 pm
If in ticket, region mentioned as EMEA then it remind to IT agent send mail xxx 2 pm to 10 pm
If in ticket, region mentioned as AMR then it remind to IT agent send mail xxx 10 pm to 6 pm
Hi @Sampath ,
If I understand what you're trying to achieve, I think it is certainly doable with an automation. Let me give you some quick guidelines and see if you can give it a try and report back if you get stuck.
trigger - issue created
condition If/else
Condition field condition region = APJ
Condition - advanced compare {{now.shortTime}} greater than 06:00
And Condition - advanced compare {{now.shortTime}} less than 14:00
Action - send email
else... repeat above for other regions
oh...also consider boundary time, I.e. use >= and <= as desired
Thanks for your quick response i have tried below but audit log shows no action performed and check some tickets says the following resolution passed but i didnt get mail
Ok so I don't understand the use of a scheduled trigger. Can you restate your goal? The use of the now.shortTime within a scheduled event doesn't really work, I think.
are you trying to notify an individual on a given shift that...
Ok so why not simply set up 3 filters with subscriptions that trigger at the start of each shift?
project = ABC and status = "Waiting for support" and region = EMEA
set this to send an email at 14:00 to subscribers
Thanks for your advise , below it is working for me but i need to set the time according to the shift and time
It seems you should have three different rules then one for each shift. Schedule them according to the shift.
To be honest, I still don't understand the scheduled trigger. What is the timeframe that you are scheduling this rule to run? Maybe at the beginning of a shift?
Does the filter/subscription not meet your goals?
thanks for your reply
My condition & requirement , some tickets , we have waiting for support and that ticket needs to remind to our IT agent working on 3 different shift and timing ,
If waiting for support ticket, region mentioned as APJ then it remind to IT agent send mail xxxx 6 am to 2 pm
If waiting for support ticket, region mentioned as EMEA then it remind to IT agent send mail xxx 2 pm to 10 pm
If waiting for support ticket, region mentioned as AMR then it remind to IT agent send mail xxx 10 pm to 6 pm
i didnt try it trigger option posible to share exact steps thanks
Hi @Sampath , let me try to restate what I think your requirements are and have you confirm.
please confirm or correct/edit my understanding
