Hi, we installed JIRA software on our server and it's running as a service in CentOS server. Every time we reboot the server, JIRA had problem starting up.Here you can find the log: https://www.dropbox.com/s/poifqs6e21tixwo/catalina.out?dl=0
Thanks for your help
Make sure the user running JIRA has necessary permission to the /installed-plugins/ directory in JIRA Home. Have you copied those plugins manually to the plugins folder?
Hi, thanks for your reply. I always used Web GUI to install pluglins. Which is the default directory for installed-plugins?
Some plugins are installed in
<jira-application-dir>/atlassian-jira/WEB-INF/lib/
Other are installed in the application home directory:
C:\Program Files\Atlassian\Application Data\JIRA
(on Windows) /var/atlassian/application-data/jira
(on Linux)You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
I follow this documentation: https://confluence.atlassian.com/jirakb/how-to-fix-jira-directories-permission-in-linux-829048437.html.
I hope I solved the issue here.
