JIRA had problems starting up
Diego Gosmar November 13, 2017
Hi, we installed JIRA software on our server and it's running as a service in CentOS server. Every time we reboot the server, JIRA had problem starting up.Screenshot 2017-11-14 08.09.24.pngHere you can find the log: https://www.dropbox.com/s/poifqs6e21tixwo/catalina.out?dl=0
Thanks for your help
Suhas P
November 14, 2017
Make sure the user running JIRA has necessary permission to the /installed-plugins/ directory in JIRA Home. Have you copied those plugins manually to the plugins folder?
Diego Gosmar November 27, 2017
Hi, thanks for your reply. I always used Web GUI to install pluglins. Which is the default directory for installed-plugins?
louisdj
December 5, 2017
Some plugins are installed in
<jira-application-dir>/atlassian-jira/WEB-INF/lib/
Other are installed in the application home directory:
  • C:\Program Files\Atlassian\Application Data\JIRA (on Windows)
  • /var/atlassian/application-data/jira (on Linux)
Diego Gosmar December 5, 2017
