JIRA instalation without graphical interface
Erick Prieto June 12, 2018
I can install JIRA, on a Centos 7 without graphical interface.
Unpacking JRE ...
Starting Installer ...
Could not display the GUI. This application needs access to an X Server.
You can also run this application in console mode without
access to an X server by passing the argument -c
is the same result of:
sudo ./atlassian-jira-software-7.10.0-x64.bin -c
sudo ./atlassian-jira-software-7.10.0-x64.bin c
sudo ./atlassian-jira-software-7.10.0-x64.bin -C
sudo ./atlassian-jira-software-7.10.0-x64.bin C
sudo ./atlassian-jira-software-7.10.0-x64.bin --c
sudo ./atlassian-jira-software-7.10.0-x64.bin --C
Thank you for your help
Moses Thomas
@Erick PrietoTry this  since you  are using  centos 7 the following commands
  • yum  install  dejavu-sans-fonts
  • chmod x+a atlassian-service-desk.x.x.bin (give permission to all / file executable)
  •  ./atlassian-service-desk.x.x.bin (run the binary file)
Best!.
Erick Prieto June 13, 2018
thank you Thomas. It has just worked succesfully :)
Moses Thomas
@Erick PrietoGreat!  please accept solution /vote so  others  in  similar situation could use.
MoroSystems Support
June 12, 2018
Hi
I downloaded the .bin file. I don't made any change on it.
In another product, I dont remember exactly but I thing what was confluence, I ran the binary as executable wizard for made the instalation.
MoroSystems Support
June 12, 2018
ok so try to follow the instructions in the link I posted...
