JIRA is not triggering workflow transitions
Deepali Agarwal June 6, 2018
I have JIRA clould and I have integrated it with github. I have created triggers and the trigger details show its working fine.
For example - Below is the trigger to move an issue from To Do -> In Progress.
I created a issue in JIRA, committed in github with the JIRA ID. In my jira issue I can see the commits but the issue is not transitioned to "IN PROGRESS" state.
Here:
PS - I have saved my workflow, my project has the right workflow and have waited for more than an hour to make sure authentication and syncing happens.
Randy
June 6, 2018
There will be a delay unless you add a webhook.  Make the changes outlined in this page: https://confluence.atlassian.com/jirakb/slow-appearing-commits-from-bitbucket-or-github-in-jira-779160823.html
Deepali Agarwal June 8, 2018
Thanks it works now. Looks like there was some delay.
