I'm trying to add a issue filter macro to my work place.
I've been looking at the advance filters here https://confluence.atlassian.com/jirasoftwareserver070/advanced-searching-762877735.html
and here
When I'm trying to do is filter tickets from my project that are in Backlog / Open/In Progress / Done / live
I have it working to a point with the following code.
project=CS and (status=open) which will show all open tickets.
and
project=cs and (status=testing) or project=cs and (status=open) this will show me all open and all testing issues.
BUT.
Some of my workflow names have 2 or 3 words "In Progress" or "ready for dev"
I can't figure out how to use these in the search... when I was something like project=cs and (status=in progress) it doesn't work because of the 2 words and space
I've tried inprogress / in_progress / in-progress / in+pregress and nothing is working.
How can I search 2 or 3 word workflows ?
Or another option is to show all status but NOT this one but I can't figure out the correct code.
project=CS and (status IS NOT done) this would return all the ones I need but can't figure out the correct way to use the IS NOT operator.
Any help would be great.
Thanks.
JQL has auto complete feature. If you try to type "in" it will advice you to all posibilities.
Use this JQL;
project=cs and status="in progress"And also you can use below for your other problem;
status != Done
thank you. thats perfect.
One more question. Is is possible to do something like this
project=cs and nj and pa and status="in progress"
So i'm search 3 project boards and returning all the In Progress tickets for those 3 boards.
You can use "in" function
project in (cs, nj, pa) AND staus = "in progress"
this worked :D thanks.
Going to leave it open In case anyone can help with the IS NOT issue.
