JIRA system dashboard - missing permissions
Jörg Bofinger October 5, 2017
Hi community,
i've a phenomenon wich I can't  understand...
My colleague an me, both are users with "jira-system-administrators" privileges - among others - aren't able to reconfigure the system dashboard.
The messgae we thereby receive  is "...Sorry, you do not have permission to modify this Dashboard..."
What could the reason for this purpose be?
What ca we do to get back the permissions?
THX in advance
Jörg
2 accepted
Nic Brough -Adaptavist-
October 5, 2017
You're not looking at the system dashboard, you're looking at someone else's dashboard (probably a copy of he system one)
To edit the system dashboard, go to Admin -> System Dashboard.
Gonchik Tsymzhitov
How did you understand it is copy not System?
From question I understand it is System, but problem with permission on group level.
@Gonchik Tsymzhitov - You are right... my question is about the system dashboard...
I'am absolutely wondering, because I can't remember that anybody has changed something within the global permissions...espeacyly not for the jira-system-administrators???
What kind of permissions do I need? - I'am not sure???
Gonchik Tsymzhitov
1. Could you open this link?
{{JIRA_BASEURL}}/secure/admin/EditDefaultDashboard!default.jspa
Can you change it?
2. If not please, review you permission in this sections before checking for which group you are membership
{{JIRA_BASEURL}}/secure/admin/GlobalPermissions!default.jspa
I hope it will help for you.
October 5, 2017
Because you only get "edit" on your own dashboards.
Administrators can *always* change the system dashboard, but only via the admin menus.
Hence, they must be looking at the system board and not remembering that the system board is only changed via admin, or they're looking at something that looks like it that they do not own.
Like Steven Schouppe likes this
Gonchik Tsymzhitov
Hi!
Could you check you group permissions below
https://confluence.atlassian.com/adminjiraserver073/managing-global-permissions-861253290.html#Managingglobalpermissions-Grantingglobalpermissions
Looks like jira-system-administrators don't have enough permission on global level.
I hope this answer will help you
Gonchik
Neil Gulati
October 22, 2018
You get this error message if you go to view the System Dashboard, and then try to use the edit link on the top right triple dot menu.
To configure the System Dashboard you need to go into the administration menu and select "System Dashboard" under the "User Interface" item in the side bar.
Thank you guys for your support!
Don't know why - but after a restart of the jira service it seems to work fine again...?
We have to observe if this phenomenon is a recurring one...
