JIRA with Key, Assignee,Sub tasks,Assignee details in Dashboard
Rk July 10, 2024
JIRA with Key, Assignee, Sub tasks, Assignee details in Dashboard
John Funk
Hi RK - Welcome to the Atlassian Community!
Can you share more details as to what you would like to see? But basically, you can create a Dashboard and add a gadget for Filter Results. If you have not created a filter already, you should do that first and make sure it is shared with others.
Rk July 10, 2024
In the Dashboard, Would like to see the User Story, Summary, Assignee & also the Subtask, Summary & Assignee under the userstory
Like # people like this
John Funk
You can't do a lot of combining of issues in the dashboard without some plugins. So you can't show information about the parent and the children at the same time. But you could create two different gadgets in your dashboard - one for parents and one for children.
First step is that you should create the filters you want to see data for. Then save those and share them once they are returning what you expect to see.
Then gadgets to the dashboard - probably the filter results gadget for what you have described, and maybe a pie charge or something like that to have some visuals.
Be sure to share your dashboard also!
Kit Friend
Echoing what @John Funk has suggested you probably won't get this view from a single Dashboard widget - the default gadgets can't show nests of subtasks within their parent issues. Dashboard filter widgets are basically just a flat list of whatever you tell it to list without a concept of what is above/below what:
Using the List view in your project sidebar does show hierarchy - here's an example showing a task broken down into sub-tasks. The columns are configurable so it might help you.
vieview
and/or you have Jira Premium, you can use Plans to show a full hierarchy tree breakdown easily which might fit - the fields shown are configurable also:
Rk July 12, 2024
Thanks;
Like John Funk likes this
Danut M _StonikByte_
Hi @Rk,
You can display this info in your dashboard by using the Work Breakdown Structure Chart (WBS) gadget offered by our Great Gadgets app.
This gadget display the issues from a filter or JQL in a tree hierarchy by Epic > Stories > Sub-tasks along with their current status.
So, if you configure the gadget with a filter that returns the tasks and the sub-tasks, you will have the info displayed.
See examples of this gadget (and the many others offered by the same app) in this article: https://community.atlassian.com/t5/App-Central/8-gadgets-for-a-powerful-Scrum-dashboard-in-Jira/ba-p/1683063
This app is free with Jira free plan. Otherwise, you can start with a 1-month free trial. If you have any questions, feel free to contact support@stonikbyte.com at any time.
Hope this helps.
Danut
FREE
