JMCF - WAS and CHANGED operators for custom fields
Steven Baynes September 28, 2022
Using JMCF, is it possible to use the WAS and CHANGED operators for custom fields?
Ex, "Custom field" WAS "my value"
2 accepted
David Fischer
@Steven Baynes
you cannot use WAs and CHANGED for calculated custom fields. Not sure you can even use them for any custom field for that matter.
Steven Baynes September 29, 2022
Thanks David
Benjamin
HI @Steven Baynes
You might want to submit a ticket with the vendor to double check.
https://jqlsearchextensions.atlassian.net/servicedesk/customer/portal/2
Usually custom fields don't have these options.
-Ben
Thanks Ben
