JMWE post function auto add component based on parent issue
Nicolas Andika
Dear all,
I have created a workflow for subtask issue. I want to create a post function in the create transition to set issue fields (Components) based on the component field value of the parent issue? how to make it happen? whats the value of the nunjucks template?
Thankyou
Manoj Gangwar
Hi @Nicolas Andika
You can use.
{{issue.parent.fields.components}}
Nicolas Andika
Hi @Manoj Gangwar
when i use this and i test it, the result is empty Screenshot 2024-09-24 at 16.49.07.png
Manoj Gangwar
Then you can use the Copy issue fields post-function
Nicolas Andika
Hi @Manoj Gangwar
Thanks for the help, it works
FREE
