JQL - Does not contain operator (!~) usage
Raj Vora
I am trying to use the Does Not Contain operator to identify any issues in my entire JIRA instance where the Summary does not contain the word "411";
So my JQL statement I use is (summary !~ "411"), while this seems straightforward, the search still generates results that have the "411" string in the summary.
I read the advanced searching page here:
https://confluence.atlassian.com/jira064/advanced-searching-720416661.html#AdvancedSearching-KeywordsReference-DOES_NOT_CONTAIN
but can't find any solutions.  What am I missing/overlooking?
Thanks.
6 votes
Mahesh Patel
November 1, 2022
Try this one
!(summary ~ "(411)")
Raj Vora
Yes, this works!  Thanks.
Like # people like this
Phil Bustin
April 1, 2024
This isn't working for me: !("SBM Tracking No" ~ "K")
Amir Katz (Outseer)
August 26, 2019
See the answer by Ignacio Pulgar (May 9, 2018) in this thread:
https://community.atlassian.com/t5/Jira-Core-questions/Search-for-issues-that-do-not-contain-text/qaq-p/455633
The secret ingredient is how to use the filter:
<some-criteria-here> AND FILTER NOT IN (<filter-ID>)
Definitely counter-intuitive IMO...
Alexey Matveev
October 3, 2018
What is your Jira version? I just tried on Cloud and it worked.
Raj Vora
JIRA v7.5.2 (Server)
Alexey Matveev
October 3, 2018
Try to query like this:
summary !~ "411*"
Raj Vora
unfortunately that doesn't fix it either; not sure if it has to do with the fact that I am searching based on numbers
Alexey Matveev
October 3, 2018
Could you give me examples of issues which you can see, but they should not be selected?
Raj Vora
The summary for a few issues that appear in the search results but should not:
Issue 101 - 85411 - Something is wrong
Issue 102 - 85411 - Something is wrong again
85411 - Something is still wrong
Alexey Matveev
October 3, 2018
That is right. You are not able to filter these issues out because Jira looks from the beginning of the words in the summary field.
For example
Issue 101 - 41123434 - Something is wrong
would work.
